I've ordered a 'custom' pc from that second hand high street store...
9 Dec 2006
@ManCave
:D, either way, thou must update the thread with the result of this gamble.
i found a refurbished PC online from a reputable custom built Office brand & reseller was selling it
emailed manufacturer ALL proper parts (ASUS,gigabyte,kingston)
No. Description Qty. per
1001420 Contender mATX Silver chassis with 250w FSP PSU 1
1000059 IEC C13 to UK Plug PC Power Cable 1.8m 1
1002437 Gigabyte H510M-H mATX Motherboard 1
1000499 Delta FHSA9025S-1525 82w Intel skt 1151 Cooler 1
1002538 Intel Core i5-11400 Tray 6-Core 2.6GHz LGA1200 CPU 1
1002565 256GB Lexar NM620 NVMe M.2 SSD 3000MB/R, 1300MB/W 1
1001280 8GB Crucial DDR4 3200MHz DIMM CT8G4DFS832A 1
£269
was going to buy it & make it into a Gaming PC for my daughter but need she dont need a upgrade right now (she doesnt game enough) still using xeon from 2011
9 Dec 2006
@ManCave
I asked the shop what the board was, should've asked the rest really but who doesn't like little bit of a surprise :p
But been advised its a Gigabyte H310M H 2.0.
I'm still expecting the punch technology build above now..
I've ordered a z390 a-pro board.
punch are very reputable office brand :)
OP
29 Sep 2010
Yeah I took a look at their site, doesn't look too bad, but imagine it's the same with most pre builds if it is one, I.e often skimp on psu / board, but not that bothered as I've got a decent psu and board on the way which didn't cost me much and I'm sure I can sell or re-purpose the other board and psu somehow :D
Turns out the 'dispatch' is the courier being arranged, dpd just advised it'll be collected Monday and delivered Tuesday.
9 Dec 2006
@ManCave
what i mean by this, is they USE proper parts, punch system i saw for £294 used a gigabyte H410 & off brand seasonic 200W
they skimp in the right areas but use qaulity parts
OP
29 Sep 2010
Oh fingers crossed then :D well that's even if it is one by them, complete stab in the dark but does match the specs.
9 Dec 2006
@ManCave
this was the build i found online from a retailer so reached out to punch via email for spec they sent this 30 minutes later
£269
epic price for a litte gaming rig (add gpu/psu)
OP
29 Sep 2010
Can I ask what's the purpose of going to a Z board? Just more USB ports?
It was a good price and better vrms for the 9700f really to hold the full boost as had past H310 systems where they couldn't maintain it. Might end up getting a k chip at some point later down the line but not sure.
Plus 2 ram slots sucks on any board that isn't itx imo.
OP
29 Sep 2010
I suggest filming the unboxing just in case it's just...a case!
I'm going with low weight due to 500w ish psu/stock intel cooler/single fan 1660ti.
Had a Google... I reckon its going to be this and they've just incorrectly listed it at a 2tb ssd....its the only thing that matches unless it is an actual custom built pc by someone.
H310 board in this, not great but beats oem! According to the description its got 2 x dimm slots and a sole stick of 16gb, which isn't bad to upgrade to 32gb.
Just says 500 watt psu.
free photo website hosting
I was bang on with this prediction, its this exact system, zotac 1660ti, and they listed the hdd as an ssd so will have to sort that out, wonder how good their cs is...I can't fault the condition though, looks like it's never been touched since it was made by Punch in terms of cable management..hdd was dangling down though!
Forgive the flooring we had our central heating changed yesterday :p
free picture upload sites no registration
