MOT had the following emissions fail versus last year
mechanic was suggesting it could be oxygen sensors , or failing cat - any opinions ?
Oxygen/lambda sensors are ~£100 each there are 2 on each bank (e: 2 downpipes each 3 cylinders) before cat (bmw M52 i6 ), used for controlling mixture, so I don't want to change them if not necessary.
anlso 2 after cat , apparently just used for EML lights (nothing shown)
I had cleaned the MAF recently and will be checking there is no vacuum leak, if there were a small leak could it be so dramatic ?
some web comments I'd read
- jiggerd 02/Lambda sensor usually shows up as high HC (hydro carbons/unburnt fuel) => so maybe not lambda, it doesn't use much oil either.
- exhaust leak would give a high lambda reading.=> no leaks afaik
- plugs and air filter then a damn good thrashing just before the retest. => haven't yet done/inspected plugs
- Bottle of Catalyst cleaner wouldn’t be wasted either, => I've put in some BP ultimate so far, car had been idle for 3 months, did maybe 10miles before mot to warm it, mpg doesn't seem to have deteriorated in post mot drives.
(posh nail varnish remover or equivilant that burns slightly hotter or burns with lower emissions)
- CO is carbon monoxide not CO2 and is the gas of incompete combustion so it must be running inefficiently, bad plugs, burnt valves etc
