Computer running slow playin games !
No its not.
That means the memory is running at 2133mhz so you need to go into the bios and find xmp profile and set to 3200mhz.
Then check again.
Cpuz should say 1600mhz if correct as its for memory double data, 1600mhz x 2 = 3200mhz
hey bud thanks for the help..
i have had a look in the bios and it lets me turn on XMP but dont let me change anything
https://ibb.co/DMWCD4r
https://ibb.co/LZSyhrF
You could try setting the frequency manually if you disable xmp profile but things become unstable and you may have to reset the bios.
What bios version do you have ? as updating he bios may fix issuies but does come with risk.
i need to do all them manualy. i did use the bios tool but it only updated to 23f..
Yes do it from the bios and on a usb drive but please read the description of all the bios versions before as it looks like you have to update to f31 first then f40 and so on.
Q flash.
Q flash.
i have tried using q flash but it dont let me select the file even tho i have it on a USB drive.. does the usb drive need to be fat32. i can use the @BIOS to update but i know it risky. (stress) :p sorted it changed the USB to fat32 and now its working. wish me luck :D
its now running at 3000mhz, hopefuly its working now and dont crash :p
Not being able to run the full 3200mhz is probably down to the weak memory controller on the 2700X. the zen 2/3 chips have a better memory controller so if you upgraded to say a 3700X in the future you'd most likely find 3600mhz is achievable.
