- 18 May 2010
Oh great, do I still submit readings as normal or is that pointless now and it gets sorted once whoever it is takes over?
This is asked on nearly every page of this thread. The advice here, on OfGem, the news and providers who are going under is to not switch.I'm with Bulb
Is it worth starting a move to someone like Octopus Energy now?
#metoo
So why did they/bulb choose this moment - german uncertainty over the pipeline, shareholders decide to cut their losses/keep trousers, weather forecasts
r4@one expert suggested there will be more blood, without specifying who
If i recall Bulb needed someone to plough more money in for further investment. I suspect that never happened, or they couldn't secure enough for what they need to ride the storm, ergo going bankrupt.
I think there's still quite a few smaller players in the market who are hanging on. So probably not surprising that "there will be more blood".
Ouch. I'm with octopus and paying 19p on the variable.FYI I spoke to Octopus earlier this morning. Their fixed rate is around 35p/kwh for elec and 10p/kwh for gas at the moment.
Could see a big name go?
Just not Octopus please... Literally just switched from Bulb about two weeks ago.
Only just been switched from Avro to Octopus, I'll feel cursed if Octopus go under as well.
The recommendation is still to submit your readings as normal. I'm still submitting mine to Pure Planet even though they've gone and it's in the process of transferring to Shell Energy. Doesn't look like it's a quick process, but that's not really an issue.
I'm with Bulb
Leave everything as it is. Don't change supplier and don't cancel your direct debitOh great, do I still submit readings as normal or is that pointless now and it gets sorted once whoever it is takes over?
