- 27 Oct 2006
- London
Custom panel finally done, added flow meter and a few more cyberpunk themed decals to finish off the exterior. Changed the sensor panel layout to match the theme and added some Phanteks Neon light strips, 4 in total. Made a few adjustments to the tubing as well as it was quite parallel in my rush to get the rig running so i could test all the components worked.
All thats left now is the MoRA3 360 and another D5 pump to aid with flow rates but not 100% sure its needed yet.
Hi Jay,
Brilliant build
Do you happen to have a build log or can you share what that small LCD display is ?
Cheers
