- 24 Sep 2015
@Freefaller have you tried fast.com set to minimum 30 connections.? This and torrents are the only 2 ways I can max out my ~1.2Gbps connection.
Monitor your connection in windows task manager while doing that. Mine sits at 1.2Gbps.
Edit:
Just tried it now and I’m getting about 650Mbps with 30 concurrent connections.
Honestly Virgin is a pathetic ISP.![]()
I don't trust fast.com in the slightest. I've got 900Mbps FTTP with an internal gigabit network. Fast.com will very often give me results like this which is simply impossible:
