- 2 May 2011
- Woking
I thought he retired from doing live performances. Clearly not!
Only from touring. He said he's happy to play single performances.
Yup it's not a bad pub, haven't been for quite a few years though.I heartily recommend a nearby pub called Oddfellows. Great place with a lovely garden if the weathers good.
the concourses are not great places at Vicarage Road, very tight and dark.
Let’s see your actual nails, how close to that picture do they get?My annual Christmas treat to myself!! Totally impractical but I love them!
They look more Halloween than Christmas to me. Where from ? I think my oldest daughter could have some fun with those.
Yeah and that picture was uploaded over 2 years ago.The watermark from this STOCK IMAGE says "Perfect 10 Custom Nails" They have an instagram.
I don't understand how they work, I understand digital ones that replace the old ones directly but I don't understand smart TRVs and how to tell the difference. How do you heat a single rad without heating all the others!?
Yeah only the starter kit so wireless thermostat, extender (that connects to boiler), and internet bridge. Nothing else so far.do you have any of the other TADO stuff? I really need to get round to doing something as our gas bill is astronomical, and a few of the "normal" TRVs have failed in rooms we don't use
Depends on your boiler and the system you get but most smart TRVs sense room temperature and can be programmed on a regular schedule to heat/not heat certain rooms
For example my bedrooms are heated in the morning, but that's it. Whereas my lounge is heated in the evening. The office is heated all day etc
My smart thermostat is also able to modulate/control the boiler internal temperatures (Bosch system and Worcester boiler), learns how long it takes to heat certain parts of my house and can compensate for the temperature outside
Thanks for the explanation but I'm still confused. If I understand correctly you can't just have one of these on one rad in the house because when that one TRV calls for heat it will heat the other rads with dumb TRVs with it. You would have to have them fitted to every radiator in the house to keep the others rads from heating if you only wanted to heat for example an office room radiator during the the day?
YesThanks for the explanation but I'm still confused. If I understand correctly you can't just have one of these on one rad in the house because when that one TRV calls for heat it will heat the other rads with dumb TRVs with it. You would have to have them fitted to every radiator in the house to keep the others rads from heating if you only wanted to heat for example an office room radiator during the the day?
