- 6 Aug 2009
- Wales
I changed from a 9900k at 5.1Ghz to a 12700k and with the cheapest DDR4 board I could find at the time, the MSI Z690 Pro non WiFi. I had already seen a few vids about that board and it did seem good to go.
I have only just finished building it up, the 12700k is still at stock and will probably remain so for some time.
For me and my needs I was focussing more on CPU types of games where it can be somewhat difficult to measure an improvement.
As a rough guide I saw.........
This is with my 9900k running at 5.1 Ghz..........
38 FPS.
If I dropped from 1440p to 1080p the performance would be exactly the same. The game is more orientated around IPS and does not use multi cores very well.
This is directly after my build and with zero overclock.....................
so from 38 to 52 FPS and around a 33% increase, not good at Maths tho.
The game is Workers and Resources Soviet Republic. Whilst that is only one, not very exact, measurement I am hoping that Cities Skylines, Civ type games and the campaign maps of Total War games, turn based, will improve.
I just would not have thought that I would have seen such an improvement from a 9900k overclocked to 5.1Ghz to a stock 12700k.
The E cores do get used in other games..................Civ VI......
I'm happy enough with my early findings - of course I'm always happy after a build when the PC goes through POST...................!
The Windows 11 install from my Z390 was used for the Z690 build, installing the chipset drivers just before the change. All seems well once reactivated.
Appreciate this vimes thanks bud, certainly a nice improvement there! i'm so tempted to just pull the trigger and move to AlderLake.
i was about to check out with a 12700k and the Asus strix D4, but can't see an option for delivery for tomorrow
well i've ordered, slight changed of plan though, change the CPU to the 12600Kf, along with the Asus Strix D4, i'd rather save the £100 difference going to the 12700Kf, after speaking to a friend that's moved from a 8086k @5.1 to the 12600k, he's extremely pleased with the performance increase, so i'll give it a go too.
