Hi all,
Because of the whole DR lottery with 16GB memory sticks I bought a few 32GB kits but now I'm not 100% sure what to keep so need some help with the decision as someone more knowledgeable might steer me the right way.
I've bought:
Crucial Ballistix RGB 32GB 3600 kit (have 2)
BL16G36C16U4BL.M8FB1 16GB DDR4-3600 16-18-18-38 1.35V
Crucial Ballistix RGB 32GB 3200 kit (have 2)
BL16G32C16U4BL.16FE 16GB DDR4-3200 16-18-18-36 1.35V
Team Group Pro Dark 8Pack 32GB 3600 kit (just 1)
TDPPD416G3600HC16GBK 16GB DDR4 3600 16-16-16-38 1.35V
This is for a new build so no idea how good the 5900x will be, but I expect the MSI X570S Carbon Max to be pretty good with overclocking (no idea on memory topology).
Not a massive overclocker so just wanted something that will match my CPU 1:1 hopefully over 1800...
I know the Ballistix 3200 kit is deffo DR from the 16FE suffix while the 3600 lot is SR as it's M8FB1. Both are obviously Micron E die. No idea about the Team Group stuff other than it's Samsung B die so I thought all 16GB sticks of that had to be DR but have no way of telling I think without putting it in the system.
Just want an idea what you guys would use, I think I only wanted 32GB (2*16GB) as I doubt think I really need 64GB (4*16GB) for gaming and software dev. Need to return some of it though!
TIA
ps3ud0
I've bought:
TIA
ps3ud0
