Just had a near panic attack this afternoon repasting with Liquid Metal. I bought myself a Corsair HX1000 PSU to give me a bit more headroom and decided at same time to LM the Ultimate (and wave my warranty good bye).
Power supply fitting went fine. Although the switch on the PSU has me a bit confused as its the 12v SINGLE or MULTIPLE setting. Single all 12v rails are free to grab as much as they can, MULTIPLE limits each to 40A max. Googled this but could find
anything conclusive or recently (2021) so left it on default.
Already had experience with LM when I delidded my 8700k. This time I was extra careful with all precautions taken. Went well it seems assembled back power on PC, no display.
Panic creeping in it tried various things nothing. Calming down took it out and disassembled. The spread on the heatsink didnt look right, not enough contact then I thought first time I
put the screws back in the wrong sequence (GPU 4 last) so could be that. Respread existing LM on both heatsink and GPU, assembled it again, made doubly sure the PCIE plugs were
in securely, panic starting to build, turned it on and..................... YES a display. Phew. Panic over.
Set my Radeon Software to 2500-2700 on core, 2120 mem, +15% power and ran Timespy. Where my hotspot would shoot to 105-106c on the 2nd test it now maxes at 89c! (GPU temp 63c down from 73c)
Tried Superposition 1080p Extreme and hotspot maxed at 89c with GPU at 69c, previously I think GPU was 79c. So far its been a result.
