Well if you are seeing higher power draw and clock speeds, then you know which one is accurate.Yes, That is the process that I have followed. I can see the voltage going up to 1.206 mv in HWinfo. Also, with default voltages, HWInfo never reports anything above 1.175 which is not the case after applying voltages and GPUz is reporting 1.262mv as well. I am puzzled ?
