Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
He did have some humming problems last night so he's just ordered this - https://www.amazon.co.uk/dp/B00ACZO9VE/ref=cm_sw_r_cp_api_glt_fabc_08FGRZ86A9VJ9PTX1YSB
I am not saying the Mondo is the wrong choice, it should do what he wants to do, and it's a solid PSU if you bought it 10 years ago. However, things have moved on quite a bit in the last couple of years. Strymon brought out the Zuma and Ojai, Cioks brought out the DC7 with expansions. Fender has brought out the Engine Room. Basically PSUs these days tend to target every output to have lots of power to reduce the headache of power allocation. You just plug it into any socket and it should work.
This PSU below much much better, more modern, more power, more power in every socket and this more flexibility. 500mA in every socket, all isolated. (when in stock).
Every socket is 500mA, and there are 12 of them, the Mondo max is 400mA and only has 4 of them.
Also 20% cheaper.
https://www.peachguitars.com/fx-pedals/power-supplies/fender-lvl12-engine-room-230v-uk.htm
Here
https://www.guitarguitar.co.uk/product/201202364714025--fender-lvl12-engine-room-power-supply
Another alternative is the Cioks DC7, 7 sockets at 660mA with a USB socket. All the sockets can do 9, 12, 15 or 18v. Expandable with more sockets with their expansion if you need to later. It's also really small, fits under a PT Nano.
