- 29 Dec 2004
- Shepley
We've just moved into a new (old) house and having some issues with one of the toilets. Initially, it was backing up and not flushing properly but this was cleared with a plunger and is now working fine. The issue we're getting is occasional bad drain/stale urine smells in the bathroom. This only seems to have happened since the plunging, so I wonder if this has disturbed something. It's not great. A load of bleach seems to cure it but it's not really a long term solution.
Google says replacing the wax seal may resolve the issue. I've had a poke around underneath and there is also a relatively large gap between the floorboards and wastepipe. It doesn't smell terrible at the moment but there's a definite draft coming up, and a bit of a "drain-y" aroma.
My thoughts were to replace the wax seal (is this what I can see on the flexible pan connector pictured?) and fill the floorboard gaps with some expanding foam. Is this a terrible idea?
