No, although someone correct me if I am wrong but the 12600k and 5600x are pretty much equal in terms of gaming performance. Plus you'll need a new motherboard, so you'll end up paying, say £240 for the 12600 plus another say £200 for a motherboard to have similar performance to keeping your 5600x
I can currently get a 12600KF for £240 but is it worth it over my current 5600x?
this x 1000 . People will feel Intel buyers remorse once AMD 3D drops....No, definitely not. The performance is pretty much the same and Zen 3D is on the way for AM4.
power consumption on Intel ADL is actually very good in gaming workloads.no upgrade with bigger time gaps. those are too close together. plus i think the intels use a fair bit more power for not all that much gain really
No zen 3d till 2022 though as it's delayed because of TSMC. wonder if it will use intrachip microchannel cooling?
https://www.igorslab.de/en/intel-co...ng-in-really-fast-and-really-frugal-part-1/9/
The 12600k has 4 more cores though albeit small ones and is a 125w TDP part so being that close to the 6 core 65w 5600X is pretty decent, the 12400 which has the same amount of cores and same TDP only pulls 45w while delivering the same performance as the 5600X so ADL clearly has good efficiency in gaming workloads.According to that at 1080P the 5600X is 64 watts with the 12600K 69 watts.
Does that matter? i don't think it does, the reason that crap keeps getting posted by others is because the 5900X uses 13 watts more at 1080P than the 12900K, that was really important to them.
Price/performance: 5600X any day
You can use it in a great x470 board like MSI Carbon Pro (~£80 used with high-end quality VRM unlike Asus which is crap - see Buildzoid's take on them on YouTube). It is the same quality as a £400 Z690 MSI Carbon board. After BIOS update you also have PCI-E 4 gen, which can not be saturated currently. X570 is literally marketing, nothing else. The only thing you would need is good memory (3600Mhz and up - but make sure that Infinity Fabric is 1:1) but the whole system would be still way cheaper than the any Alder Lake if you compare like to like.
If you however don't mind to spend roughly +50% for 15% increase in single core performance and have a decent cooler by all means go for Intel. Bear in mind that at QHD and up the FPS difference is negligible and for productivity there are better CPUs out there.
