Man of Honour
- 23 Mar 2011
- West Side
Cas 18 to cas 16 isn't worth 50% more in cost for a few fps imo .Thanks for your reply.
The patriot viper has higher latency doesnt it? CAS 18 vs 16. Do you think the Corsair Vengeance DDR4 32GB cas 16 for £150 elsewhere would be a better option?
The RMx is slightly better quality than the RM isnt it? From my understanding the fan will be a bit quiter etc
I dont really need pcie4, but I think I will go for it anyhow!
Rmx is better quality both have 10 year warranty not sure on the fan noise but i think thats down to when the psu was built plus 30% more in cost, best check out some reviews. .
