That's more like it
Use top cashback or similar and enjoy decent broadband, FTTP is much better than VM.My VM deal has ended on my 350 package and my monthly cost has gone up to £55 a month. I'm really tempted to change over to BT FTTP 900Mbps but am I likely to get any better deal than what's currently on their website - £49.99 per month? Cheers
BT tend to play hardball and your unlikely to get better than what's listed.My VM deal has ended on my 350 package and my monthly cost has gone up to £55 a month. I'm really tempted to change over to BT FTTP 900Mbps but am I likely to get any better deal than what's currently on their website - £49.99 per month? Cheers
FTTP is so worth it over Virgin - the stability is much improved, both on the network and router side of things
I've ordered it - due for installation on 18 January Problem is: The fibre will come from a pole across the road, and I live in a dorma-style house. The cable will have to go to the highest point on the house (which is the loft) but we've recently built a single-storey side extension which prevents access to the side wall. Will they use a bucket lift or something similar to get high enough?
Go with whoever works best out for you, BT are doing an Xbox game pass currently and EE do discounts for mobile customers. The ONT is the 'modem', you can plug in whatever compatible router into that if you don't want to use the ISP one.Guys, will be leaving VM soon as I can get full fibre 900 here now but I have a few questions. Go EE or BT? also one more thing, can the routers be changed to just modem mode? Cheers in advance
