No issues with DND either. Even properly blocks calls from non-starred contacts.
No problems with double tap and auto rotate on my 6 pro too.
@Dirk Diggler have you checked if these are repeat callers? You could try turning that off and see if that fixes it, in case it's people trying to call you multiple times.
Another thing you can try is Bedtime mode under Digital Wellbeing, and see if that works any better.
