Thank guys for highlightng options I hadn't thought of.
At the moment I'm minded to go with the Intel spec above (MSI Pro Z690-a board & a 12700K) as it's the best i'm prepared to spend out on at the minute. However, I'm also debating the 5800X as it can be had £50ish cheaper and pairing that with a Gigabyte Aorus Pro B550 v2 or a X570 Gaming Edge Wifi (not that I need Wifi, but wil be nice to have when passed down), OK I lose some functionality (PCIiE 5 and 4 NVME), but (hopefully) get a higher quality board for less cost. I'd be in the same boat as regard expandabiity if I went B660, so Z690 seems the logical choice if going Intel but the £200 boards seem to be described as budget!
The 3060ti, I was just lucky to get hold of and has really forced my hand at the minute but it will likely to be replaced at some point, wheras the cpu/mb/ram will be unlikely to change, for at least a few years.
I hadn't thought of the 10 series or the 12400 so that's another rabbit hole! I don't chase massive performance so I don't get the upgrade itch often when it comes to core system upgrades.
