Any idea why sometimes my firewall connects to the WAN I get 5ms ping and then if I disconnect and reconnect it I get 9ms ping? This is Zen 900.
It is for me, I have some VMs which are in the cloud (as I don't really want to run them at home due to resources) and I have a VPN to them. The application starts moaning if the latency is over 10 ms and the difference in gateways and the additional latency of the VPN moves it above this threshold. Not a major thing I admit as functionally it'll work but still annoying!I get the same, one of the gw's gives me a 4ms ping and the other 6ms. No real world difference to be honest though![]()
The other issue is they seem to rebalance quite frequently so even if you disconnect to get the better gateway, in the early morning a random number of days later they drop the PPP session and cause a reconnect and you re join the lottery.They probably won't touch it at all as their teams aren't equipped to even attempt reinstatement of that sort of surface. If you lowered your requirements to them not doing the reinstatement other than filling the hole back in then that would probably be enough.
In case people aren't aware, if BT have switched you over to Digital Voice you may be eligible for a free wi-fi enabled cordless phone:
http://bt.com/dvequipment
You should get a pop-up asking for your landline number so they can check eligibility, turn off your adblocker if it doesn't appear.
My parents were switched over a few months back but seemingly weren't told, it was only when I was having a dig around on the BT website that I stumbled across it.
Yup and the only place to get certain Linux distributions which aren't on private trackers.
Can't be bothered signing up. Password for my BT account doesn't seem to work.In case people aren't aware, if BT have switched you over to Digital Voice you may be eligible for a free wi-fi enabled cordless phone:
I didn't realise there were two. Try OpenreachHelp
Nice! Mine is in a box in the garage as a spare, might see what I can get for it.That being said I do not use the provided Fritz router (infact I sold it for £100!)
No complaints from me, always seem to get what I pay for 900/100.
That being said I do not use the provided Fritz router (infact I sold it for £100!) as I have a pfSense and Unifi Setup.
They are more expensive but they can provide the features that I wanted (static IP/IPV6) for a reasonable price and the guarantee of no price rises.
