Got a new mug, well not my main mug but just something with a bit of novelty :p
Ceramic, quite beefy and holds the heat so all good there.
I love it!!
:D
Official Sennheiser headphones storage. A fancy quilted version of the basic ones that come with the headphones. I've long since broken the stock one so been using a cheap Amazon case for a while...
Nice. I have that mic, I think it sounds fantastic.
It really does, I used to have a small bit of EQ on the AT2020 and a bit of a noise gate as it had a really loud self noise (20dB). But with this I've turned all that off and it sounds amazing, I might put a bit of EQ but I dont even know if I will need to bother. It also hardly picks up my keyboard with Blue Mechanical switches which is amazing too.
I got one of them for free by emailing Sennheiser and just asking if they had a spare one lol.
not sure if they will do that again now though as they stopped bundling headphones with even the standard hinged boxes with foam inside a while back and instead just shipping them in cardboard boxes!
Grabbed this last week after my wife dropped a decent amount of protein powder on the kitchen floor. Neither the robot vacuum or the very reliable but a little dated Vax hand-me-down that we have could reach it from under the toe kick. I couldn't be bothered going to the garage anymore to grab the shop vac for little jobs so got this while it was on offer.
It's got a decent amount of power for the price and the battery lasts long enough to do the whole house in terms of a quick 'dusting'. Same make as my robot vac and all of my home security products which I love so I knew it would be well made. Not a fan of the purple accent colour which I think makes it look like a hairdryer but otherwise is fine.
