I switched pretty quickly to vpower after running e10 for a few weeks, in a morning the engine would misfire or be very hesitant until it warmed up and from £20 of fuel there was very little difference in mileage so use vpower or the Tesco equivalent.
DERPIf you knew me in real life you'd damn well accept my answer, because you'd damn well respect me.
My Mazda Xedos 9 won't run on it properly tbh. So now having to put proper fuel in and use super in this car as well annoyingly. Seems in the cold the start wasn't anywhere near is good (or just bad timing) but deffo not as economical.. i.e. normally get around 290 miles on a full tank was down to 250 on E10... it's not an exact science but what i found it just didn't run as well, switched back to Sheel Nitro and all good again. Then again it's a 2000 based on a platform from 1996 so to be expected, what annoys me more is the fact I now am forced to put considerably more expensive fuel in... which is £1.65 per litre for Nitro... I accept this in the SRT8 but not in my "run around". Hey ho...
Wrong. I got 24 mpg from 95 RON before it was changed to E10, putting in E10 I got 18 MPG.
I then put in 98 RON as 95 RON in non E10 form is unavailable where I am - my fuel economy then returned to 24MPG.
For what its worth, my engine is designed for 95 RON - and it states on the petrol cap there are no benefits to running anything higher.
You see.. you shouldn't try and fill in the blanks, without understanding what the blanks are your mind will skew things in the way of your desired outcome.
It's actually a form of ignorance, which may explain why you are so quick to put down people giving their experience with this fuel?
Its either you're ignorant, or you're a shill for the EU commission!
Funny how a couple other TFSI owners on this thread have mentioned an MPG drop similar to what I experienced.
But hey... its probably just the weather!
RIGHT?
Derp.
This is hilarious.
And no, if I met you, I wouldn't respect you.
Yeah I've used momentum before and runs normal and sweet but there's not one close, I have to time it when I happen to go miles away then pickup... I agree the extra SHELL tax hahaha is hard to stomach tbhThis is hilarious.
I'd find a Tesco with Momentum 99, I can't stomach paying almost 20p a litre more for V-Power now.
I almost always use Momentum 99 in my car, but Tesco didn't have any (on two separate days I visited) so I put in £20 of E10 last week, from empty.
Totally unscientific, but fuel economy appears to be a bit worse, performance and "smoothness" is worse and acceleration is quite sluggish and not far off how the car felt when I had issues with the turbo. This is in a 2014 Seat Leon FR 1.4 TSI so it's a modern enough engine.
I agree, it is simple.The math is quite simple, it worked out at 25% Are you exaggerating or do you struggle with basic equations?
I will claim it, because it was my experience.
Claim it bogus, go ahead, you're only doing yourself and the rest of everyone using E10 a disservice to flat out deny someone's experience based on what?
Because I said it on a forum?
But not if you knew me and my accomplishments
But crack on, just another forum pleb right? I couldn't give a **** what you think.
Not noticed any change here, Ford Fiesta (2020 model iirc) 70mile round commute, 20% city, 20% motorway, 20% a/b road.
Fill up at Texaco only, same petrol station, same pump. Have been getting 49mpg for last couple of years, still getting around 48-49mpg, distance to empty same as it’s always been. Not sure if E10 at the pump has to be E10? Could Texaco could still be supplying E5?
Only odd coincidence, is one of my O2 sensors failed a couple of months ago, around September time.
Instead of getting so emotional with your responses, you should try to reply intelligently to any rebuttals..
The fact that you keep posting nonsense, indicates otherwise.
Where are these attacks you keep speaking of?attacking
