Puget data suggests Intel CPUs generally were more reliable than AMD's in 2019-21 (Not Rocketlake!)
14 Aug 2018
https://www.pugetsystems.com/labs/articles/Most-Reliable-PC-Hardware-of-2021-2279/
I'm not too sure what to make of it as Rocketlake was very poor compared to 10th gen Intel, Hmm... CPU's have very low failure rates so I probably wouldn't be too worried about it!
At a 8-1 offset in retail sales I don’t think we can draw much of a conclusion.
Getting a sense Puget Systems have lot of Xeons and Samsung drives needing to find homes in workstation.
I would be interested to see what HDD’s have the lowest failure rates.
The chart shows a completely different story.
Intel score 8.28 points in failure rates, AMD score 6.87, you would only conclude AMD has a higher failure rate if you ignore 11'th gen entirely, which seems to be what they have done, they seem to be saying "well it seems odd so we are going to ignore it"
11'th Gen Failure rate is near as high as all of AMD's put together.
I get the a sense Puget have over ordered on some kit :p
That's hilarious that their blanket conclusion on AMD ignores the massive erection of 11th gen on intels side.
In general, as long as we erase 11th gen, amd was worse :)
You'd hope so from Xeons as they are over-engineered/toleranced and highly tested/binned off the cream of the silicon hence you generally pay a lot for them.
No, it doesn't.
Puget said:
AMD CPUs in general had higher failure rates than Intel, but we did see an oddly high rate of failures with Intel's consumer-oriented 11th Gen processors... which seems odd, especially next to the very low rates shown by the preceeding 10th Gen.
It's you doing math, not Puget. Puget said AMD were generally worse but 11th gen Intel failures were abnormally high. which is exactly what the chart shows.
Have to agree with humbug on this(Did I just type that! )
In percentages terms that reads as Intel is worse when adding the totals . Something rather striking regards 11th gen being that high .
You're wrong. you made the wrong conclusion. period. Stop trying to sugggest you're more intelligent than people who can actually comprehend what puget said.
This isnt about percentage terms. It's about what Puget did and didn't say (and what Humbug accused them of saying). And you shouldnt come to any conclusion based on any one abnormal data point.
