If you think about it, it actually makes perfect sense.
very true its a top tier card its meant to be special or have some extra features slapped on there.
Its the supercar of the GPU world.
Which is what almost everyone said when it was released. Lots of people only bought the 3090fe because getting a 3080 was not possible for a sensible price. The 3090 FE isn’t much more than lots of 3080 AIB models.Only for games you can't leverage the vram, it's completely pointless and will not engender you towards the opposite sex either, unlike a supercar.
Who needs 24gb of vram? Certainly not a gamer.
If nvidia had the same business practices in 2005 as they do today. The would have released a 7800gtx with 2gb of vram and charged £800 for it. When the 256mb version was fine.
I will give you that with the 24gb Vram but the 7800gtx also had a 512mb version which is double the Vram of the normal card. It would set you back £430 back then. So again thats the top chip with an overkill amount of Vram at the time.
For the 3090 to be worth the premium over the rest then it really should have been manufactured on the TSMC 7nm.If you think about it, it actually makes perfect sense.
Lets be honest, a 3080ti was always on the cards from day one. For the 3090 to make any sense it needs something to differentiate it from the 3080ti and the 3080 given they are all within 10% of each other.
The only way to increase the VRAM was to double it and it looks great on a spec sheet.
The AMD equivalents also look great on a spec sheet with their 16gb, half of which is unused in nearly all games. The only difference here is that 8gb wouldn’t have been enough for the higher tier cards
That was a long post above. So my 3080fe is a 3070, and I should be thanking AMD.
My mind boggles.
I bought a new graphics card. It's a 3080fe and it plays games. Isn't that the only thing that needs to be understood?
Trust me. I wasn't trying in any way to make any sense of what was written.You clearly didn't read it...
The real 3080 should have been the current 3070. The 3080 you have now is thanks to AMD making Nvidia move every card up a tier.
Why was that hard to understand ?![]()
You need to do a TLDR summary, because your posts are incredibly convoluted and long-winded to the point where I gave up reading it. No-one likes walls of droning text that do not hold interest; please be more concise and get to the point.You clearly didn't read it...
The only cards that aren't absurdly priced this generation are the FE cards (aside from the 3080 Ti) and the tiny number of AMD MBA cards that vanished like a fart in the sahara.
There are still reasonable upgrades to be had when looking at the resale value of old cards, however.
Those FE cards wont exist next generation either
Hard to say, Nvidia certainly lost out on a lot of profit but the fact they've kept restocking has probably earned them some good will (which was then battered by the 3080 Ti I suppose).
