Would love to build one of these.
What are your costs?
Formbot kit? I got their V0.1 kit and I was very happy with it.
Where did you get your printed parts?
Good luck with the build.
PLA+![]()
Blurolls on AliExpress.Where were the mounts from that you got? (the 'bad' ones).
PLA+![]()
Got over 300 hours on it now with the PLA+ motor mounts and still haven't had any problem. Got replacements in ABS+ but have no motivation to change them![]()
What material are you printing on the printer and for how long on average?
It's not necessarily that PLA+ isn't strong enough, it's that it's glass transition temperature is lower. Voron's were designed as enclosed ABS printers, so 50-60°c enclosure temp, 100+°c bed temp and 250+°c hotend temp. PLA and even PETg will fail quicker than ABS.
Exclusively Esun ABS+. The Z-Axiz motor mounts are outside the enclosure in the cooled electronics area. I am running 110 bed and 255 hotend. I doubt the motor mounts ever get higher than about 22 degrees celcius.
Should be ok then .
How would you rate the kit overall? My formbot V0.1 kit was 98% ok, but they sorted it out.
