- 27 Oct 2021
- Bedford, UK
Still installing, been going for almost an hour now!
Same, I reckon it was around 90 mins in total.Finally finished.
Sometimes I put my finger on and it just gets it straight away, almost instant and then other times it takes a second or 2 but it does seem to get it more first time than before the update.Maybe I'm imagine it but the fingerprint scanner seems quicker.
Same here, 41.25mb on my Pro, coming from the Dec update.
Thanks - I wonder if there is an issue with my phone. The other day AoD drained nearly 50% in 24 hours! :O
Has everyone got the same build now or different?
Mine - SQ1D.220105.007
Pixel 6/Pro January patch
- Framework:
- Fix for issue causing screen to unlock after missed call when no screen lock is set.
- Network & Telephony:
- General fixes & improvements for network
- Fix for issue preventing emergency calls in certain conditions while some third-party apps are installed.
- Power:
- Fix for issue preventing Pixel Stand setup to start after updating apps in certain conditions.
- System:
- Fix for issue causing incorrect data usage accounting in Network menu on some networks.
- User Interface:
- Fix for issue causing a black frame to appear when dismissing the Assistant overlay on the lock screen
- Fix for issue causing memory leak in system UI under certain conditions.
- Fix for issue causing navigation bar to be hidden when switching device orientation in certain conditions.
- Fix for issue causing PIP window to render incorrectly for certain apps.
- Wi-Fi:
- Fix for issue causing Wi-Fi network to drop connection in certain conditions.
Network & Telephony
- Improvements for data connectivity on certain networks and conditions *[3].
- Fix for issue preventing use of Call Screen feature on certain networks *[3].
- Fix for issue preventing emergency calls in certain conditions while some third-party apps are installed *[4].
Same I went from Dec to JanYep mine's the same.
Had that as 2ell... annoying...First thing I've noticed, they seemed to have fixed the bug where the phone randomly manually locks after a certain time and asks for my PIN instead due to smart lock. It now properly asks for my FP.
Took roughly 90 minutes to install, but I finally have a signal in my house again!
That issue is fixed on my wifes phone where it was broken before. I had to turn OFF the "Enable Face Detection" in Auto rotate screen settings page. If you have it on it now only stops the numbers on the camera screen from rotating when you turn the phone, this is only when you double press the power button to access the camera from the phone when locked. It works as intended if the phone is unlocked and you tap the camera shortcut.The only issue I had with the phone (and hoping now fixed) was the auto-rotate/tap back sensor stopping after an undetermined time until reboot (could stop after hours or perhaps a couple of days)
