- 5 Aug 2015
According to ekCPU Block compatibility list
- Intel LGA-1200/1150/1151/1155/1156
- Intel LGA-2011(-3)
- Intel LGA-2066
Mounting Bracket
- Metal backplate for Intel LGA 1700 socket based motherboards
- Rubber insulation for the backplate
Looks like you haven't ordered compatible parts
Yeah does sound like it matePhone lines are shut today, will have to try on monday. Yeah the parts should work, as mentioned the backplate adds support for the 1700 socket to the original velocity. Ordered that as it was half the price and in stock compared to the other 1700 block at the time.
The holes all line up from block through mobo, rubber layer and the backplate, just the screws do not fit in the backplate. I think the backplate has a manufacturing defect, eg holes not drilled to correct size. That free EK backplate is the same one I ordered from OCUK.
According to the site, should use the same screws.
- Necessary mounting screws are not included in this upgrade kit. You need the screws that came enclosed with the water block.
Probs just got unlucky and got a badly made one.
This is on me I should have been clearer, the backplate used in the photo is 'EK-loop Intel CPU Backplate M4' Not am4, I should have worn my glasses reading the packet!Have you been sent the correct block because if you ordered a Intel block it shouldn't come with any AMD fittings as EK have split them into Intel and AMD versions these days and not universal like they used to be? If you have a AM4 backplate that must mean you were sent a AMD block surely? That would explain why the posts don't fit in the 1700 backplate.
I wasn't confused to begin withYeah was a confusing thing to explain, well I made it so
All installed and working great now![]()
What sort of watercooling nut
Doesn't have a drill or dremel
Sorry couldn't resist that
Only ocuk can answer if they would open it to check
I know I tried in a major high street retailer
With an item and they wouldn't
Not with the same item but similar reasons for wanting
To look before I bought it
