The OCUK Whisky (and Whiskey) review thread
28 Aug 2006
Hexham
Thanks for all the advice on my next bottle, ended up buying the one I'd been eyeing up for a while anyway, the Caol Ila, but plenty of options for the next next one. :)
23 Nov 2019
Caol ila is a nice whisky. IIRC a lot of their output goes into JW black so it doesn't get as much volume to do big runs of aged bottlings but what they do release tends to be good. Every now and then they do a low/un-peated and those are really fun. I got to try the 2017+2018 versions and they were quite something. Each slightly different, one a bit white chocolatey.
9 Nov 2009
Planet Earth
JW Green was surprisingly nice - got some last year for £25ish which I thought was a bargain for a 15 year old vatted malt.
9 Nov 2009
Planet Earth
Wow, that's different! :eek:
Just having my second glass, the first was a shock to the system, TCP/antiseptic and a little smoke, added some water and it was much better.
Second glass going down much better, still with a touch of water, starting to quite enjoy it.
As the whisky gets more air the taste can change a bit. So as you continue down the bottle,or keep it in the glass for a bit it will probably mellow out a bit.
27 Oct 2002
Scotland
A word of warning, don't always expect adding water to peated whiskies will take the edge off how peaty they smell and taste, it can actually have the opposite effect. It's more likely to happen with higher abv whiskies 46%+, but again that also isn't always the case. I won't bore you with the details of why it happens, but just give you a heads up in case you come across it as I've seen people drown their whisky thinking they just haven't added enough water when it occurs.
28 Aug 2006
Hexham
Good tip, I'll remember that one.
The third glass was better again, had that one neat and really enjoyed it, perhaps i just need to be tipsy to appreciate it? :cry:
On a side note, we took the dog to Cambois beach this morning, and the seaside smelt almost exactly the same as the Caol Ila...
23 Nov 2019
I'm intrigued why does it do that? Presumably some chemistry thing due to the complex molecules in peated whiskies?
9 Nov 2009
Planet Earth
The taste is determined by chemical compounds and adding water changes the soluability of them,especially NCF whiskies. Long chain esters especially can be quite water insoluble.
Chilling Filtering is done to remove some of these compounds as they precipitate out as the ABV drops(which adding water will do),so it could be the taste changes since the compounds are moving out of solution and settling out?
23 Nov 2019
I drove to caol ila distillery once and got there to find it closed for maintenance. Never did get to go round it. Like most Ila distilleries it is on the coast but the taste is mainly due to the malt and peating and stills used. I don't think they store barrels much on site anymore. I find Laphroaig worse in terms of TCP. Seaweed however I can see where you're coming from
9 Nov 2009
Planet Earth
Rumours are that Laphroaig 16 and similar older whiskies are going to have some big price increases this year.
22 Jan 2014
Indeed, very few distilleries' casks are actually stored on Islay. Some keep a few there to say that some whisky in the bottle was aged on Islay. Lots just distil it there, then tanker off the spirit to the mainland where it's casked and stored.
27 Oct 2002
Scotland
Basically the phenolic compounds are in solution in the alcohol, the water releases oils and brings them out of solution. Needless to say it's more complicated than that, but that's the gist of it.
25 Nov 2020
Hi all
Never really had much whiskey before, what would you all recommend for someone like me wanting to move away from lager and cider to the odd whiskey now and then?
Cheers
What kind of flavours do you like? Smoky? Sweet? Floral? Cereal? Etc.
The world of whisky is incredibly subjective.
23 Nov 2019
Start with a basic/nice blend and see if you can get on with it. If not don't spend too much on anything as it might not be your thing. If you like it then start looking at tasting sets of single malts to help see where your interests lie.
27 Mar 2016
Bristolian living in Swindon
More of a sweeter taste would be for me I think, what brands would you recommend?
What sort of one's would you recommend with a little sweetness to it? Also do you mix it with anything?
27 Oct 2002
Scotland
Are you dead set on scotch, or are you interested in whiskies in general? As I'd normally suggest bourbon if you want sweet. Buffalo Trace is one you can often pick up from Amazon for £18 on offer, so isn't breaking the bank if you don't like it. And you can always make old fashioned cocktails with it if you don't like it neat. Just beware at the moment as Amazon have a half bottle of it for £18, that's not the one to go for, make sure it's the 70cl bottle. It's £23 at the moment, but as I say it is very often on offer for a fair bit less.
The problem with recommending scotch to people new to it is there is such a vast array of taste profiles, it's hard to narrow it down, plus good ones tend to be a bit more expensive, which can be off putting to a lot of people. But if you do want to try one Tomatin Legacy is £24 on Amazon just now and may be something you'd like. Monkey Shoulder is another you can pick up relatively cheaply, it's a blended malt though, rather than a single malt. Johnnie Walker Black Label (a standard blend) when you can get it for £20, or Green Label (another blended malt, but this one is 15 years old, at least) when you can get it for under £30 are all worth trying. They may not be the very best, but they are decent and good value for money at those prices. You just need to be patient and pick them up when they are discounted, which again is quite often.
But the Buffalo Trace or Tomatin Legacy would be my suggestions to start with.
