Hey,
it's been over 20 years since I built a PC and a lot has changed. I have been watching youtube videos daily for 2-3 months and I have settled on a build but I need it kindly reviewed.
Current PC spec
Monitor- Samsung LC34J791WTUXEN
CPU - Intel i5-8500 3ghz
Mobo - ASRock Z370 Pro 4
GPU - EVGA GTX GeForce 1070 FTW
PSU - CoolerMaster 550W
Case - Aerocool 1000
RAM - G.Skill 32GB 2133MHz
AIO - Corsair Hydro Series H55 High Performance All-in-One Liquid CPU Cooler, 120 mm Radiator
My current PC I got at the start of the pandemic second hand for £500. Since then I got the 2K monitor and all the games I play are on the 3440x1440p resolution.
My basket at Overclockers UK:
Questions
8. What sort of value can I expect if I sold my existing GPU?
Current PC spec
- 1 x Lian-Li O11D EVO Mid-Tower Case - White= £149.99
- 1 x Corsair RM Series RM850 850W '80 Plus Gold' Modular Power Supply (CP-9020196-UK)= £84.95
- 1 x Asus ROG STRIX B550-A GAMING (AMD AM4) B550 ATX Motherboard= £179.99
- 1 x Crucial P5P 1TB M.2 2280 PCI-e 4.0 x4 3D NAND NVMe Solid State Drive= £112.99
- 1 x AMD Ryzen 5 5600X Six Core 4.6GHz (Socket AM4) Processor - Retail= £319.99
- 1 x Corsair Hydro Series iCUE H150i Elite CAPELLIX RGB WHITE Performance Liquid CPU Cooler - 360mm (CW-9= £169.99
- 1 x Corsair Vengeance RGB Pro 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - White= £79.99
- 1 x Cooler Master MasterFan MF120 Halo ARGB LED PWM White Case Fan - 120mm= £10.99
- 2 x Cooler Master MasterFan MF120 Halo ARGB LED PWM White Case Fan Triple Pack - 120mm= £39.95
Questions
- PSU, is 850 watts enough? The PSU needs to be able to support at 3600Ti in the future. I’d prefer a white version but it's an extra £30-40 for the paint job…
- The Corsair memory has RGB on it, will the icue software detect it automatically when fitted into the mobo?
- Can I confirm I don't need to mess around with the BIOS on the mobo with the selected CPU?
- I plan to use my existing GPU until I can get a new one at a sensible price. Can I confirm my 1070 will work fine on the new mobo?
- Originally I had planned to buy all Corsair QL120 fans but they are too expensive, so I’ve changed it to Cooler Master MF120 fans. With 3 intake at the bottom, 3 intake on the side, 1 rear exhaust, 3 exhaust via the rad top mounted, am I creating negative pressure or is this setup ok?
- The AIO, I wanted the MASTERLIQUID ML240 ILLUSION WHITE EDITION however it doesn't come in a 360mm version. There is a MASTERLIQUID ML360L ARGB WHITE EDITION V2 but I can’t find it on the OC website, therefore I have defaulted to the Corsair H150i AIO.
