In these day and age it helps to be decisive!i ordered, now im cancelling
Indeed, bought a vega 64 from there that wasn't fulfilled so I offered £200 (which is what the vega 64 was listed at) and was amazed that it was accepted! Might be one off with the nature of them not being able to fulfill my order.
I bought an RX470 on these forums a couple of years ago for like £40-50 for a friend. This card is about as fast as that....
Or a GTX970 which came out in 2013 is about a similar sort of speed. What a poor card.
No wonder it has disabled media encode features,look at the power draw:
https://tpucdn.com/review/asus-radeon-rx-6500-xt-tuf-gaming/images/energy-efficiency.png
This is really bottom barrel silicon being used!
They threw the power budget (of going to 6nm) at the 1ghz clock increase as making it a 40w part would kill the performance.
It is saying a lot about 6nm and 5nm to come.. Now we know why next generation is going to be a bigger power hog.. In todays climate sadly £180 is a good deal on a new card with these sorts of specs. Next generation pricing is clearly going to be threw the roof and power use, heat generated by these new cards.. Say bye bye to the rumoursed 2x-3x performance increase to 7900xt over the current 6900xt, same for 4080 will be 20-30% increase if we are lucky at a more ridiculous msrp from the start.. Sad times for the GPU market.
The 3060Ti is pretty much the best budget card if you could have gotten one at MSRP anyway.
Well in terms of price/performance it seems hard to beat anyway, depends on your expectations on framerate & resolution.depends on how you view Budget even at msrp a 3060ti cant be described as budget in anyway shape or form
unfortunately its for anyone who doesn't have £400 to spend on a GPU... It sucks to be themso tldr version is
Only buy if you have a PCIE4 motherboard and CPU, and even then its a dubious card. So that precludes anyone who hasn't built a new system in the last year. But then those people probably already have a graphics card.
So who is this for? If this was a 1030 or 1050ti priced card, it would be more appropriate.
unfortunately its for anyone who doesn't have £400 to spend on a GPU... It sucks to be them![]()
