Right, I have been kicked out of the road cycling thread and told to come talk to you shut ins about Zwift
What is the minimum setup I need to have a good Zwift session. I don't want to spend more than £400 if possible, less ideally if it doesn't massively compromise the quality. Happy to go second hand as well.
I have ipads, monitors etc and I have a bike already.
Do you also want to use the bike for outdoor riding?
Depending on that question will answer whether you need to buy a separate cassette for the turbo or to jst use the existing cassette and have the bike as a permanent Zwift bike, which would save a little bit of cash.
Alternatively you can switch the cassette from wheel to turbo, but that would be a real ballache
mine stopped working and I gave the strap a good soak in Zoflora and cleaned the corroded contacts.
