Stuck - Need a dual monitor arm, in white
11 Jun 2003
Hampshire
I'm really struggling to know on the market is both suitable for my needs, and actually good; I'd be immensely grateful for any advice.
I've currently got a very beefy, hinge style through-desk monitor arm for my X34p. I want my work PC to also be on a monitor arm, so I thought why not combine the two for less desk clutter.
Ideally I'd like a white, through desk dual arm, with the flexibility to have either next to eachother, or one above the other. I appreciate that last one is likely a tall order.
Requirements / Must Haves
  • Through desk
  • White
  • Shallow mounting (ie can go against wall with minimum monitor protrusion)
  • Ability to move the 34" forward / back
  • Capacity for a 34" 21:9, and a heavy 27" 16:9
  • Side-by-Side support
Nice to haves
  • Gas strut style
  • Built-in cable management
  • Vertical set up also possible
Product suggestions, links or alternative ideas are all very welcome. Any input whatsoever is appreciated.
nam
nam
18 Oct 2002
London
Hi, got 2 single arms recently, works well for my needs. I think I can post the link here if it helps from amazon
https://forums.overclockers.co.uk/posts/35399888/
  • Through desk
  • White
Nice to haves
  • Gas strut style
OP
11 Jun 2003
Hampshire
Hi mate, thanks for that. It appears the link has been removed, at least I can't see it.
Could you inbox me a link? Can't find them. Also, do they come in white?
