- 21 Oct 2011
- ST4
Doesn't bother me in the slightest. I'm English, so can easily switch between imperial and metric when required. Just don't get me started on US imperial measurements though.
Anyone else getting sick of everyone bloody using km to measure distance and kg for weight within the UK? For example, I ran 10k today or I weigh 80kg. No you ran 6.2 miles and weigh 12 stone.
KG is the better measurement anyway. Literally everything is weighed in KG, so why not bodyweight too?
Do people send their parcels weighed in stones when booking the item in at checkout? Are cars weighed in stones or KG? Is everything else weighed in KG or stones?
KG just offers a better basis of comparison and an overall better metric for weighing things.
Miles for distance, KG for weight but we will probably need tonnes for yo moma.
When the dinosaurs walked the Earth, gramps?back in my day
No, I'm not sick of people using the global standard units of measurement. Particularly since it's a very good system of units. Simple, useful, etc.
In practice I use a mixed bag of metric and imperial in daily life and I convert in my head as required. It's not a big deal to do so for daily life because an approximation is good enough. If I need accuracy for anything I'd be using metric anyway. I only use imperial because it's what I was raised with and are thus used to. Metric is far simpler. None of this 3 things to a whatsit and 13 whatsits to a doodah and 1473 doodahs to a weeble or whatever. Imperial units made sense in the past as a combination of custom and convenience in the middle ages, but metric is far simpler nowadays.
Is anyone sick of people no longer using units such as rods, chains, barleycorns, cubits, etc? Although strictly speaking some people do still use barleycorns as that's the standard unit of length in the imperial system. The imperial inch is the medieval English inch and that was defined by royal decree as 3 fat barleycorns side by side. Other units of length were defined in inches, i.e. in groups of 3 fat barleycorns. It made sense at the time. Grains of barley were quite uniform in size and the use of three and the specification that they were fat increased the uniformity. Grains of barley were easily and cheaply available and would keep for years if they were kept dry. It was a convenient way to make it practical for people to check lengths. In the middle ages. We don't need that sort of thing today.
No, I'm sick of this perpetual hybrid situation we are in where we use multiple scales for the same measurements.
Imperial weights can do one as far as I'm concerned, we should cut over to full metric (most goods are sold in metric now at least). I can see a bit of light at the end of the tunnel, I think stones will die out with the older generations. I'm in my 40s and think of my weight in KG nowaways.
In terms of distance, it's more complicated because we have a lot of infrastructure dependent on imperial i.e. road signs, car speedometers, general way we talk about distances. So I can at least see why that persists, even though I don't particularly like it.
Olympic sized swimming pools, double decker buses, jumbo jets and football pitches are the tabloid measurement system of choice.
No, since the mid nineteen sixties I have been using both measures, the last forty years predominantly metric. A non issue.
Kilometres came easy, I found it easy to think of distance in km after spending a few years truck driving around Europe, but I still think of speed in mph.
It’s all arbitrary anyway.
I think this went unnoticed, are you a politicianGive the man his due. All those "meetings" at 10 Downing Street were surely to discuss reinstating Imperial measures. Why else could they possibly need all those samples of strange foreign liquids bottled in the incorrect sizes.
