What is it divided by 3 or 6, though....?![]()
Did you learn decimal places at school?
When did you last use fathoms or links or chains? Or acres?
Or have you never needed to use a 13A plug? Or is your electricity 230V mains? Thats SI (metric). You simply can't avoid it.
Enjoy your pint.
Actually 1947. And we use metric units for electrical conductors.The 13a 3 pin plug was invented in the UK about the 1930s
So while you're trying to figure out how to measure an infinitely recurring decimal place, I've already finished work and gone for a pint.Did you learn decimal places at school?![]()
I wouldn't have measured it in centimetres to begin with...Go on then. Tell us how you measured that 100cm in inches then divided by 6 without any rounding...
Yes....Are you measuring critical aerospace engine parts? Or the length of your table????
It doesn't make a difference how you measure it, it's still the same size. It doesnt fit neatly into a fraction of an inch so you need to round it.I wouldn't have measured it in centimetres to begin with..
However, 100cm is 3' 3 3/8ths", which divided by 6 would give you 6 9/16ths".
A bit more exact than 16.6666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666....
It's not more exact.
You've rounded your answers to get neat fractions and ended up with a less exact answer as a result.
6 9/16ths" is 16.66875cm, not 16.6...
Apparently not....It doesn't make a difference how you measure it, it's still the same size.
The division doesn't fit neatly into fractions of a centimetre either - Base 12 has more even splits than Base 10, so why would you expect an uneven Base 10 measure to split evenly using base 12 measures over its own?It doesnt fit neatly into a fraction of an inch so you need to round it.
Even my cheap tape measure does 32nds". The expensive one at work does 64ths". Both are more exact than a milimetre measure.It's not more exact.
I think this thread proves that for some things metric is best and for others imperial units work as well or better. But it is open for people to use whichever they please as long as it is safe and practical.
A pound to one old penny, someone strongly disagrees.![]()
[..] Even my cheap tape measure does 32nds". The expensive one at work does 64ths". Both are more exact than a milimetre measure.
That's the classic one to bring up.
As an engineer in a previous existence I was momentarily flummoxed by poundals when reviewing calculations prepared in America. The force required to accelerate a mass of one pound by one foot per second squared. Having used archaic English units for older structure in the UK with Dorman Long steel tables and also modern SI units, newton's, metres and kilograms, it added another level of complication.That's the classic one to bring up.
Makes you wonder how the American's ever did any kind of engineering.
Although since they like to draw technical drawings in thou's (aka 25.4 microns), they at least are good at pretending to be engineers.
Also, they are clever enough to not have to remember how many pounds to a stone as they don't use stones!
Time is astronomical and no mathematicians have derived a better scale to define it. As for the other I will not get into thatIs a normal clock using metric or Imperial?
What metric do women use to define their age, most older ones seem to use a different one to men....![]()
It says EC Class I, being ±0.4mm over 3m, with a maximum 0.001% margin of error.And less exact than a micrometre measure. Also, how exact are those 1/32 inch measurements on your tape measure?
Not at all - The former is a factor if you're actually measuring, in response to the assertion, "It doesn't make a difference how you measure it"... while the latter is more about highlighting the differences between the units, and how you do get different results depending on how you measure it with each of them.But you're mistaking accuracy of measuring equipment with accuracy of units of measurement.
But how often is it actually measured to that same degree of accuracy in the real world, rather than just rounding up to a decimal place or two?A metre is defined with vastly more accuracy than a late medieval English inch (which is the inch you're using).
