- 2 May 2011
- Woking
You should have used the bum washer, they're great!
Yeah he's a plumber not a tiler, and will have a lot more lucrative plumbing jobs lined up than fixing a wall tile. I doubt you'll see him again.Thanks for all the replies alieviating my fears.
Well I've tried calling him today as I found a spare tile to do a replacement and he promised to come fix it for a cheap price and well...pretty sure my number has been blocked. Which sucks.
Can't you just pop the tile on yourself? Few spacers, tile adhesive and grout. Just make sure any old adhesive is removed (as much as you can). Spread it on nice and thin to begin with then notch it, back butter the tile and pop it on.
I'm handy enough to do that, but by the time I buy all the supplies in order to do so, it's more expensive than getting him to do it for the price agreed. Theres a hole that needs to be cut in the tile too which I need to buy a bit for.
One of the jobs (putting a stop on the bidet) is now leaking too.
Ok I will bite surely that job the man of the house could have done on his own ?
Agree with this to be honest.sounds reasonable to me, i mean he's asked for £200 first and then something went wrong and charged an extra £70 aint nowt wrong with that in my eyes. j
I'm pretty sure you can pick up some tile adhesive and grout for less then half the £40 you've agreed to pay for him to come back and finish off??Thanks for all the replies alieviating my fears.
Tbf, many people have their car serviced by a garage but are easily competent of doing it, talking oil and filter change.
you couldn't just fit a new washer your self and save £40 ?Fit new tap to replace one that was dripping - £40
