I don't think the CPU matters much as is, my GPU sits between 98 and 100%, but we could do a low resolution test if you want to compare CPU's.
Result:
Video uploading.
Make sure you use the same settings.
R9 Fury x is nowhere close to a 980 Ti it was laughed at when it was released...
Uploading..Video, should be 1440P, at the time of posting its still 1080P
Shadowplay has about a 5% performance impact.
Custom IQ settings, Preset Ultra is not Ultra, some things you have to set manually to Ultra, watch for that when setting it up.
2070S vs 3070, be interested to see![]()
lol...Also your 2070S seems to be under performing according to OC3D.
And my 3070 thrashes the 2080 Ti...
Oops realized I read the 2080S results lol.
BenchmarkResults 2022-03-04_22-10-17That looks pretty good, what was the result? you will find it in C:\Users\yourpcname\Documents\My Games\Borderlands 3\Saved\BenchmarkData
Also you're haven't got your 5800X running at 5Ghz![]()
- FramesPerSecondAvg: 81.79
- FrameTimeMsAvg: 12.23
Yeah I am scared of causing Nuclear fission in my room if I OC it.![]()
81.8 / 65.5 = 1.248 (+25%)
whatever cooler you have might struggle to cope because of the heat density from the tiny die but they actually use very little power.
https://www.techpowerup.com/review/amd-radeon-rx-6700-xt/29.html
Fine wine came into play as usual. There ain't a big gap between the 2070s and 5700xt these days.
At release the 2070 and 5700xt were around on par but now there is a gap and the 5700xt sits in between non super and super. Chart below from the same site.
Your experience is outdated due to drivers and games.
https://www.techpowerup.com/review/msi-geforce-rtx-2070-super-gaming-x/27.html
Unreal Engine games like BL3 always favoured Nvidia cards over AMD, RDNA2 does much better then RDNA1/GCN in that engine. I wouldn't compare cards based solely on that, just like I wouldn't base it on heavily AMD favoured games like Forza.
Yeah I agree, the numbers reported in the bench result are much more real, the bench seemed higher than the result showed, I went off of that.Not sure I'd call 5% thrashing tbh. Going on Humbugs 2070s scoring the same as the 2080s in than slide I'd say the 280ti still beats yours. Though the 2080ti was 1k + card at the time.
