Best way to terminate eight CAT6 cables?
18 Oct 2002
Bristol
I have eight CAT6 cables popping out of a hole in a wall (plasterboard) under the stairs, what's the best way to terminate them? Initially thinking of two 4 way face plates, one above the other but is there a better way?
You would mount the patch panel in a cabinet or open rack, either of which can be wall mounted. Look up wall mounted racks, if you only need the patch panel a 1u one will do however I expect you have some devices that could use some space to sit in ones with more shelves.
If you don't have any need for a rack/cabinet, then these desktop style patch panels can work nicely as an alternative. It can be wall mounted to if needed.
https://www.amazon.co.uk/kwmobile-Cat6-Patch-Panel-Distribution/dp/B07QK93BTX/
Tbh I'd just go for whatever will look tidiest for where you have these runs coming in. If you think two 4 port Cat6 faceplates will look neat, then go for that method. If it's in a cupboard or out of the way, the patch panel might be preferable.
