Caporegime
- 1 Dec 2010
- Welling, London
So to all the buyers , what sort of thing will be using the Studio for?
M1 is rubbish at gaming anyway, it’s all about the compute/productivity performance.
No for me, I’m new to Mac and using a 16gb mini is far faster than the pc I had for the photo editing I used to do. I’ve not had it troubled at all and neither have any of the content makers I follow for video editing, so not really seeing the need. It’s also fugly.
If gaming ever properly took off on a Mac then I’d be interested but otherwise what the hell are you doing to need that much power?
Totally anecdotal but I just converted a 4Gb .mp4 from my drone on my 2017 4.2GHz i7 iMac and my M1 MBA to h265 at the same time. The iMac took 6:53 and the M1 MBA 2:49. That's using Permute which I believe is still a universal app.As long as they are specifically optimised for the M1 - last time I checked for generic multi platform apps like Handbrake, M1 still trailed behind
In their documentation they say it's an Intel 12th gen they compared it to, so the 12900 which has 8 performance and 8 efficiency cores.They say the Ultra is faster than what I assume to be a 5950X
https://www.apple.com/newsroom/2022...s-most-powerful-chip-for-a-personal-computer/Thanks, they said 16 core in the presentation, I’d assumed it was AMD given it’s a ‘proper’ 16 core unlike the Intel.
Testing was conducted by Apple in February 2022 using preproduction Mac Studio systems with Apple M1 Max, 10-core CPU and 32-core GPU, and preproduction Mac Studio systems with Apple M1 Ultra, 20-core CPU and 64-core GPU. Performance measured using select industry‑standard benchmarks. 10-core PC desktop CPU performance data tested from Core i5-12600K and DDR5 memory. 16-core PC desktop CPU performance data tested from Core i9-12900K and DDR5 memory. Performance tests are conducted using specific computer systems and reflect the approximate performance of Mac Studio.
Testing was conducted by Apple in February 2022 using preproduction Mac Studio systems with Apple M1 Max, 10-core CPU and 32-core GPU, and preproduction Mac Studio systems with Apple M1 Ultra, 20-core CPU and 64-core GPU. Performance was measured using select industry‑standard benchmarks. Popular discrete GPU performance data tested from Core i9-12900K with DDR5 memory and GeForce RTX 3060 Ti. Highest-end discrete GPU performance data tested from Core i9-12900K with DDR5 memory and GeForce RTX 3090. Performance tests are conducted using specific computer systems and reflect the approximate performance of Mac Studio.
The Studio will be more performant in longer lasting workloads as the CPU will throttle in the MacBook before it will on the Studio. Also the 10 GbE port on the Studio. You can get adaptors for the MacBook Pro but they are far from cheap.I realise it's a bit of an odd comparison — if you need portability get a MBP, if you don't get a Studio — but, on the other hand, it's food for thought. Unless I'm missing something obvious?
My plans are always evolving. I’m now looking at the possibility of a base Ultra with a 2Tb drive and the new monitor in a couple of months.
I didn’t - do you have a link please?Did you watch that Max Tech video today? Where they suggest storage is the best value upgrade?
