I did have the heated seats and heated steering wheel on and was wireless charging my phone as well. None of which would have helped the fuel economy!
The amount of energy those things use is tiny, especially on such a short trip.
Indeed warmer weather is nice as the car heater isn't working its nuts off warming 90kWh of battery up. This is also where smaller battery cars/PHEVs benefit.
Wireless charging![]()
tHAT'S GOOD TO KNOW, THANKS.
The amount of heat my phone generates after 50 minutes on wireless charging i expected to have used 1kWh at least!
In fact my phone said that certain functions were unavailable due to the high heat! I could barely pick the phone up from the charging pad.
My old Passat PHEV used to divide the energy use over the total journey. You'd get some hilarious numbers for miles/kWh if you drove to Cornwall21 of the 30 miles each day is done on pure electric. I can currently get to and from work on a full charge. Av mpg is impressive at 64.8 (although I saw it drop to 8mpg when I pulled out onto the dual carriage until I got up to speed!) and so is the 3.4kW per mile on the pure EV.
Does the BMW do it more sensibly than this?
it's pretty inefficient versus plugging, can be 2x the energy; I'm surprised their use hasn't been correlated with long term phone reliability.Yes, some inductive chargers get quite hot running at the higher power side of things
X5 45e what is the engine warm up strategy ? do you manually suppress it's use until you arrive at a free flowing road.
Symons Tesla Model Y review after 1100 miles of family life. The good, the bad and the long term efficiency
Does the X5 not have "Max eDrive" mode?My strategy is to do nothing and let the car sort itself out. Its about 7 miles before I get to a road where the engine comes on. Until then I'm on electric only.
Yes at the time when we started the order, but price was extra £650 to upgrade wasn't going to pay that, anyway we got use to it nowdid you have no choice ? ... but I think in the UK there is a changing style for interior house decoration - strong sombre colours in living rooms so maybe car interiors are sympathetic.
With the courtesy X1 (that I've had since October now...) I mainly drive on Max eDrive, so the engine would only kick in if I were to push the throttle past the kickdown switch.
Is the screwfix one the green and white masterplug one? My brother bought that to use with his Corsa-e, nice long cable on it made it usable from a socket at the back of the garage when the car was parked out front.Had order confirmed for 208e. Bit of a change from an octavia vrs. Hopefully with the petrol savings it will work out cheaper even with my pathetic 3k a year mileage.
Looking at prices of a charge point install I think I will hold for now, maybe until the wife also goes electric.
The car doesn't come with a 3 pin charge cable which I'm going to need. Priced vary it seems from £150-£300. There is one on screwfix for for £150. Is there a difference in quality that justifies an extra £70-£80?
It is. I have a what looks like a rolec wall pod (3 pin plug socket) in the garage that came with the house. It's at the front of the garage so I could feed the wire through the gap and get a plug housing on the outside to holster it. Then I don't have to open the garage every time to charge.
No issues with charge times?
6mm for 32A
I’d not want to be relying on 3-pin charging as my main source of home charging. It’s fine for a plug-in hybrid that’ll only take up to around 4 hours to charge on 3-pin, but for a full-blown BEV? No thank you, that’s why we have a 7kW charger installed.It is. I have a what looks like a rolec wall pod (3 pin plug socket) in the garage that came with the house. It's at the front of the garage so I could feed the wire through the gap and get a plug housing on the outside to holster it. Then I don't have to open the garage every time to charge.
