Ah my life is just ****** great
During a quick pop around to my folks I suddenly noticed a raw/wet fuel smell when stationary (not exhaust). Nothing with the car seemed "off" (no hesitation, missing etc) but I pulled over anyway to check and found a fuel line quick disconnect in the engine bay has had a 20p bit of plastic locking tab decide to fail, causing the quick disconnect to partially fail and introduced a small fuel leak of about 1 drop per second at idle. The black plastic "cap" in the middle of the bottom picture should be flush with the metal pipe on the right but is clearly popped out and now won't reseat so the quick disconnect is now partially open, allowing a small amount of fuel to drip out.
I spoke to MRC and sent them the pics below, they've seen this failure before and have already ordered the replacement part but it'll take a few weeks to get here so my trip down to MRC on Friday has been delayed slightly!
It's in the pipe in the top centre/left -
The black plastic protective coating was removed by me at the side of the road so I could check for any cracks/leaks from the metal pipe underneath (none found) -
