Feek's macOS useful tools, utilities and applications thread
PathFinder is pretty good. It also gives you copy performance - this is copying to my NAS for example. You can switch it between 1000 and 1024 too!
This is how iStat Menus looks for monitoring the network, you can click on it and it has a drop down to show you which adaptor and process is using the links.
I installed Pathfinder but it doesn't show me the copy speed.. is there a setting somewhere I need to enable for this?
I use PathFinder. Supports tabs, multiple windows, file copy performance and stuff. I quite like it but I don't think it's as nice to use as explorer.
I can't find anything in settings to enable it I don't think?? Just appears in the top right.
You tried the new version, where they've moved to a subscription model now? Trying to decide whether I "power use" it enough to upgrade and am still very much in the contemplation phase. Fantastical/Flexibits was definitely worth the change for me, but not sure here.
I use Default Folder X, mainly just for one of the things it does, really ought to harness its power more than I do.
I have SetApp for next to nothing via Uni, and it comes as part of that. I'm doubtful I'd pay a subscription specifically for Pathfinder tbh.
SetApp is a great concept, I just wish it had appeared about ten years earlier because I've already bought most of the stuff within SetApp that I'd find useful so there's little point it me subbing to it now.
That’s my gotcha really. Bought so many apps individually over the years… will have a poke at SetApp again.
Didn't seem worth making a new thread, but what do people use for note taking on a Mac? I like Onenote as a concept but the lack of being able to make a true backup of the notes has worried me for years. Is there anything out there which people use?
Thanks for any help
I’ve always used OneNote stored on OneDrive. Have been for a lot of years. You can manually back up the OneNote files if you feel you have to
Can you? How do you do this? I've not usually that precious about backing things up but my Onenote had about 15 years of notes..:)
Thanks for any help
I've been using Bear for my notes, as I like the structured tagging you can see (creating trees of tags, and can have several tags per note). It's a markdown text editor, though a huge 2.0 upgrade is currently in the works to make it a nicer experience, things like hiding all the markdown when not editing notes etc. If I need something quickly I'll just use Notes.app and then transfer in the future if it's worth keeping.
OneNote usually saves into MyDocuments on PC, not sure about Mac. You also have the option on the file menu to export to a OneNote archive which is a single file with all data.
