Our semi-newly purchased house has a stove in the garden office, which I think is installed far too close to the wall.
In this picture below, the top protruding bit is 35mm from the wall, and the main body is 65mm from the wall.
This graphic (source: Wood Burner Distance from Combustible Materials Explained (stoveworlduk.co.uk)) suggests 65mm clearance is ok only in the case of a heat shield and another inch behind!
We've been using this burner through the winter to keep us warm in the external office, as the electric underfloor heating costs an arm and a leg to run, even more so as of today! But today is the first time I've really though about this.
My dad's solution (rarely by the book but most of the time does the job) is to bang a sheet of this onto the walls behind it
STS Construction Board 1200 x 800 x 12mm | Wickes.co.uk
Is that too much of a bodge? The board is fire-rated, but I guess it doesn't exactly make it fire safe, and if anything I'm just bringing the wall closer to the burner.
Is my only solution to bring the stove further out into the room? There's 180mm clearance at the front of the hearth currently, I imagine eating into that probably isn't advised. Would either need to introduce a kinked flue, or rear mount?
Now wondering who was competent enough to install this thing, but reckless or stupid enough to not worry about any clearances? Or am I missing something?
