- 21 Oct 2011
- ST4
I think my chips will be a bit crispy if I leave them in the oven overnight![]()
If you're doing chips in the oven then you have more problems than the time you're using said oven.
You either don't have a Secure Smart meter, or you need to tell them you have one and get it linked to your account, or it's not working properly !no it does not.
We have a smart meter and our energy supplier asks for readings.
If you're doing chips in the oven then you have more problems than the time you're using said oven.![]()
IMO smart meters will be the next water meters.
Early on with water meters people were all negative, bah I want to run the tap for hours and it will cost more type stuff. Over time its become clear for most that unless they abuse water its better to pay for what you use.
Everyone paying attention helps to drive down consumption, which avoids more infrastructure being needed for everyone abusing it.
So I see elec/gas smart meters as being the same. Paying for what you use when will be better for many. Real time pricing should help to pull down the big peak. People will adapt and evolve their patterns, making better use of cheap energy. Such as doing a nice slow cook over night then a microwave heat when they need it.
I think you will see the water equivalent of no meter being the elec/gas equivalent of not paying for time delimited usage, sure if you really want to have fixed unit pricing you can, but its going to cost you more than if you go smart and have variable, unless your vast majority of usage is during the very narrow window when the pricing will be at its absolute highest. IE not penalising the majority for the selfish minority.
I believe that sooner or later everyone will get a smart meter anyway, since all meters have to be replaced within a certain lifetime, so they will not fit another dumb meter (for dumb users) at that point.
no it does not.
If you had a sm now then you'd have access to your daily and your over night usage. You can see this data over time.
Yes, there's no downside to a SM and several benefits. I really can't comprehend why people are so anti.
Guarantee if there wasn't a target date set by the government to have one, and that instead of being free you needed to opt in and pay for it, all the people who don't one one would be up in arms about missing out on savings, and why should they have to pay.
It mystifies my how people cant see the above.
I've said my piece but i will say one thing that give me some mischievous joy is that those in groups 3 and 4 will have to have a Smart meter in the end, it's just a matter of time![]()
Just because your's [smart meter] doesn't do this, doesn't mean it's the same for everyone else.
it's a free solution that works for 90% of people that have them installed.
I think majority of people can but certainly in the case of electricity, a smart meter isn't the only solution when it comes to measuring usage.
Apart from completely ignoring those owners that genuinely can't get one fitted or can't make a smart meter work in their (legitimate) favour, then sure but it'll require the government to mandate it.
He say only made possible and that is the case, getting access to the cheap charging for his battery that he has bought is only possible due to the smart meter. Tell me how he would have had access to charging his battery so cheaply without the smart meter?
Over the last 28 days i've averaged 21.71kWh a day at a cost of £1.28 a day. This is only made possible because I have a smart meter.
Over the last 28 days i've averaged 21.71kWh a day at a cost of £1.28 a day. This is only made possible because I have a smart meter, solar panels and battery storage.
You have always paid standing charge this is to pay for the operation maintenance and upgrade of infrastructure including your meter. It now also covers the rental of the meter assets from the DCC and associated companies.It's not even close to being free. The most recent estimate is it will cost £13.4bn in total which is recovered through energy bills.
https://assets.publishing.service.g...meter-roll-out-cost-benefit-analysis-2019.pdf
I suppose you could legitimately say "you're paying for it anyway, so you might as well get one"; but it very definately hasn't been free.
Also I suspect the cost of the "smart meters" is probably not much more than the cost of a dumb meter (given the numbers involved), and probably works out cheaper in the long run as it massively reduces the likes of the number of meter readers and customer service staff whose only jobs are to collect and correct meter readings.You have always paid standing charge this is to pay for the operation maintenance and upgrade of infrastructure including your meter. It now also covers the rental of the meter assets from the DCC and associated companies.
The fact standing charge has been increased this year is another point entirely. And as the document you linked states the cost is to be souly on the shoulders of the suppliers, the Government and Ofgem have also stated the cost will not be passed on to customers via increased standing charge and tariffs.
The reduction in meter fraud is also likely a big saving for the companies as they should be far more capable of spotting people interfering with meters without relying on the guy who calls round once every few months to hopefully find someone in the property so they can check the meter reading (and at the same time look for any obvious signs of tampering).
No reason it wont connect, there are plans in place for adjustments to the system to make distance a thing of the past. Basically Zigbee has a max transmission range of around 30ft LOS, the more walls and structures in the way the less chance of it connecting, that said I have seen meters connect that are 40 and even 50ft apart.Unless it has changed, my understanding was the gas smart meter connected to the network via the leccy one, meaning they had to be with connection range.
Based on that I'm assuming as my gas meter outside (back) and the electric is inside (middle) won't talk together as the interior walls are solid, therefore would only operate as dumb.
A blessing in disguise. I'd never get a smart meter. Surge pricing is coming.
So if everyone is charging their car and running everything else at 4am, does 4am become the new peak time ?![]()
'Everyone' - lets clarify that !So if everyone is charging their car and running everything else at 4am, does 4am become the new peak time ?![]()
Not really relevant for most people, but just to comment on the water meter thing, water meters can sometimes significantly increase costs even for a very frugal user. I used to live in a terraced house with no meter and a tiny water bill, due to the house's low value in 1990 (which iirc is what affects water bills for people without meters). I remember looking up water tariffs at the time and even if I, as a single occupant at that time, used the lower end of estimated figures for water usage I'd have been paying about 50% more if I'd had a meter....
To use your water meter anaology, i was paying £36 a month for water unmetered and i now pay £11.50 a month. I worked out over the time i've been in this house I've literally ****** away £2000 in unnecessary water charges for no reason. I had my Smart meter a SMETS1 installed about 3 years ago and it's helped me to get a better view of my usage and my monthly costs. I've been able to change my behaviours and change some things in the house so that i used less and in turn saved money.
One key thing to note.......
Smart meters dont save you money directly however they are meant to effect behaviours and choices which in turn help you to save money. For example charging EV's on offpeak, setting dishwasher or washing machines to turn on during offpeak or cheaper periods, prompting people to switch to more energy efficient devices and lightbulbs and finally prompting people to turn things off when not in use rather than just leaving them on.
Also from a supply and generation side, we have horrific peak pricing from the generation side at the moment. Allowing mass data on supply peaks and dips allows the network and generation side to better plan the supply and account for the demand which then in thoery should reduce the cost of peak generation and this data also allows companies to offer tarrifs that incentivise people to push their usage to the more offpeak periods which then flattens the overall demand throughout the day, which in turn then allows us as a nation to try and sort out our electricity generation and plan the infrastructure and generation facilities we need to be energy secure.
