Would you mind sharing links to the accessory items you purchased?
I am very new to this and on the hunt for the right scales etc.![]()
Absolutely. I love my setup but I know it's probably a bit different to the usual, so bear that in mind as you look at what I have bought so far
Dosing funnel:
https://www.amazon.co.uk/dp/B094JMZ1DH/ref=cm_sw_r_apan_i_KZVYVX7HSJ0P1KG77MAW?_encoding=UTF8&psc=1
Dosing Cup:
https://www.amazon.co.uk/dp/B09B72MQ6G/ref=cm_sw_r_apan_i_2YQCW9DT8BDDN5J1JQTR?_encoding=UTF8&psc=1
Tamping Mat:
https://www.amazon.co.uk/dp/B097PW8BCJ/ref=cm_sw_r_apan_i_HAVXWZRY9GCTGBT7RB9P?_encoding=UTF8&psc=1
Distributor/Tamper:
https://www.amazon.co.uk/dp/B0896Q41R9/ref=cm_sw_r_apan_i_7195DVGVNAR7JY5V3Q0B?_encoding=UTF8&psc=1
I also drew up a replacement steam lever to be machined for my Sage BE. I'm still waiting for it but in the meantime the Crema Coffee lever came back in stock:
https://www.amazon.co.uk/dp/B08GDSKLPS/ref=cm_sw_r_apan_i_B8CQZBD3AA5D7MM7AYCX?_encoding=UTF8&psc=1
I really like my setup. I wouldn't recommend my scales though, which is why they're not included in this post.
My typical morning routine is:
- switch machine on and give it half an hour
- pre-heat espresso cup and machine with an empty shot through the portafilter.
- weigh beans in dosing cup
- pour beans into empty hopper and grind all back into the same dosing cup.
- weigh ground coffee to check for any loss in grinder
- fit dosing funnel to portafilter
- sit portafilter with funnel over the cup (portafilter upside down) and then flip all to get grounds in portafilter
- tap sides of portafilter to even out and settle the coffee
- distribute and tamp
- fit portafilter to machine and pour a shot of espresso
It all runs nicely now. Without the two dosing accessories I'd be flinging coffee everywhere.
