Don
- 20 Oct 2002
- In a house
They use the mobile phone network. Mine uses O2. Not sure if they all do or just certain ones.
What I found online suggests this is not the case, only some use the mobile networks.
https://www.eonenergy.com/help/smart-meters/about-smart-meters.html
If you've recently joined us from another supplier and have a first generation Smart meter, your smart meter might not work straight away but the industry is working hard to get these meters enrolled by 2022.
https://www.smartme.co.uk/smets-2.html
2G and 3G networks to close by 2033
The government and UK mobile network operators have agreed to phase out 2G and 3G mobile networks by 2033 in order to free up bandwidth for 5G and future 6G services. This includes Telefónica (O2) who provide the Smart Meter communications for the Central and Southern regions of the UK.
This change will require the replacement of communications hubs on the Smart Electricity Meters in the Central and Southern regions of the UK. To this end the DCC plan to have 4G single band Communications Hubs available in 2023, with dual band to follow in Q2 2024.
https://smartenergycodecompany.co.uk/glossary/dual-band-comms-hub/
In 2020, a more sophisticated hub with a choice of frequencies started being installed. These are called Dual Band Comms Hubs. They use a HAN frequency of 868MHz along with the existing 2.4GHz frequency. Dual Band Comms Hubs (DBCH) are expected to increase coverage to 96.5% of premises. These hubs will enable millions more British homes to benefit from Smart Metering.
