It is a long time but another way to look at it is those that jumped on the smart meters early have had to install 1st gen, then fit 2nd gen and then in a matter of years fit a 3rd gen. Personally I would rather just skip all that until I see a real benefit. When smarts improve enough I will jump aboard. As meter readers go how many people know some of the Smarts will only last 11 years? Which is rather short compared to dumb meters.
That’s got little to do with SM’s. We don’t need a SM to be on an off-peak tariff to benefit from charging a battery up overnight.
To be honest I need to redo the math's on those battery systems. Battery storage systems are not really that beneficial at least last time I ran the real numbers which was many years ago so this might not be true anymore. By real numbers I mean not the inflated marketing numbers solar panel and battery selling companies often use. Anyway by the time we have saved enough money to cover the cost of the battery its time to replace the battery which leads to a never-ending cycle of costing more money than we save. I do love the idea behind the battery systems it’s just, I cannot get the math's for them to work long term. Though that was before the current big energy price changes.
Has anyone got the math's to show a benefit from battery systems factoring in the life span of the battery and replacing the battery's over time? Part of the problem I have is not only would I need a full new battery system but I believe possibly a new inventor as well which bumps up the pay back time past the life span of the battery.
Please correct me if I am wrong as I hope at some point the pay back falls below the life span of the battery's if it hasn't already.
I believe although happy to be corrected you do need to be on a smart meter to get a tariff that makes sense to charge batteries. I dont believe economy 7 would make much sense, but its possible I guess. Otherwise you have to have a SM in order to be able to get one of the reduced tariffs.
Eco 7 is priced similarly (although worse from BG who is my supplier) to smart tariffs, and they will typically install a SM as your meter anyway as you need a dual meter to do Eco 7. (And eco 7 meters were well renown for being problematic)
Batteries do make sense, but you need to understand your usage. Oops I wasn't taking the **** there, I mean you genuinely do.
Numbers I played with put batteries at slightly faster payback than solar itself. They have the advantage that they are more predictable, in how they will generate their savings.
Eg if you dont have solar and know that you use 10KWH a day and most of that is outside the cheap charging window then you can use all that a battery will provide upto say 9.5kwh. You need to check the max discharge though, they differ so a 9kwh may only be 8.2 usable for example.
Then its simple, multiply the number of units per day usable by the difference in unit rate and your daily saving.
There are a couple of other factors that having a Sm or at least good estimates on, do you know for sure that you dont use a lot in a narrow window which could exceed the max battery discharge rate, and if it does, is your usage still able to use all the battery usage.
Then you need to make the assumption of the price differential remaining or moving in either direction.
IE run a few scenarios.
IE you need to know some basics on usage, total and when, an idea what your peak usage is, and for how long.
Solar however changes the dynamics of that, do you have excess that you export now, if so you can save that at strong generating times rather than charging from the grid.
They certainly wont be scrap either at payback time, check the manufacturers sheet for minimum lifecycles, or guarantees on remaining capacity etc They arent all the same so you need to be able to adapt your calcs.
Oh and meters have always needed to be replaced, so its only partially wasted to have updated to SMs. Mine for example is nearly 15 years old and they are generally recommended on 10-25 years so pretty much due now.
Oh you mention inventors, I assume you mean invertors. They are actually semi frequent replacements of solar anyway, often overlooked but can and do go wrong. One of the advantages of the leading edge in that if one goes down the rest of the panels still function.
