Cat poo on the lawn
Caporegime
3 Jan 2006
Chadderton, Oldham
So the lawn is really overgrown, there is plenty of patches with cat .... In it, tried picking it up with one of those nappy bags and it just turned to mush and I nearly threw up.
What can I do to effectively obliterate this cat poo pandemic of 2022? The garden is in lockdown until I can sort it out so I can mow the grass.
When our dog's has gone a bit mushy on the lawn I take the sprinkler bit off the watering can and from a height it starts to water it down.
Get some tiger **** from your local zoo and place some on the grass. You will not see any more cats. Just watch if you bring the lawnmower out but :D (clean it up first)
Short term: use a spade, then mow regularly. Medium term: get some tiger dung - they scent the larger presence - and mow regularly. Long term: get a cat and mow regularly.
Horrible things, we faced similar battle.
In the end we put down chicken wire on our borders. Looks as ugly as you like, but no more carp in the shingle
Had the same problem with cat crapping in the shingle next to my door.
Swapped it for larger stones, still used it.
In the end I put some chicken wire down and it did seem to work. Don't think cats like stepping on it.
Cats are not horrible things at all. They are loving pets. They can be a nuisance but most of us are at some point.
Is it cat poo? I thought it was on mine, but turned out to be fox poo.
As somebody says, borrow a dog, they'll eat it or roll in it until its all in their fur and not on the lawn. Just don't let it in the house afterwards. Disgusting things :D
Else, hose down after picking up as much as you can.
Can't you just use a trowel to pick it up. Once mowed it's likely the offending cat will poo somewhere else. Long grass is often cover for when they can't bury it when the soil it too hard to dig.
Are you sure it's cat poo? cats dont tend to just poo on grass, they will poo on loose mud, gravel etc. If its just in the middle of the lawn its very likely to be fox poo. Which STINKS
If my dog papped on your lawn you'd lose your mind, but for some reason cats is totally fine?
I imagine you'd get pretty upset if I started flinging it back at your house also.
I’d be annoyed, but I wouldn’t automatically think dogs are horrible things.
