Caporegime
- 13 May 2003
- Warwickshire
Love the spring!
Fake sofas????^ How a garden should be. Real grass and plants. Not that artificial stuff and fake sofas trying to make a garden like a room extension of the house.
your supposed to grow a bush to sit onFake sofas????
, get a big rock or a log@LiE What the chuff is going on with the levels and slopes in your garden?!
Thanks! Think I may be better removing the whole thing and starting again, as it's majorly overgrown in every direction. Got another one around the side which has overgrown into the washing line which does have something nesting in it.Looks like a Leylandii of sorts to me. Where it’s been cut to brown stuff it wont ever go green again. If you’re trimming the green you want to cut it close but not get to the brown underneath or the lack of re-growth leaves horrible holes. Just go at it with a hedge trimmer but not for a month just in case something is nesting in there. I usually do mine in August. You need to keep on top of it because you only have so much leeway with keeping it green but keeping the size in check. They grow very fast.
Think about how you'll remove the stumps. Traditional method is grinding them out. You can rent a machine for about £100 or get someone to do it. Because I have a lot of small trees I used an alternative method and bought a 1.5t engine crane and chain. Chainsaw to about two foot high and then literally ripped the stumps out from their roots! Cost the same as a days rental and I have an extra bit of kit which i love hoarding.Thanks! Think I may be better removing the whole thing and starting again, as it's majorly overgrown in every direction. Got another one around the side which has overgrown into the washing line which does have something nesting in it.
