- 6 Jan 2013
- Rollergirl
Wow! Well done![]()
It's a hard one today involving fractions (or 0.xyz). First time I've come across that in this game.Either my brain isn't working properly or I've got an impossible solution today.
The number before the "=" must be 2 digits. That means I need to use 2 operators up until then which would need to be:
<single digit>operator<single digit>operator<double digit>
The only operator I can use in slot 2 is division and the only 2 numbers that can use that operator are 9/3 because the 1 can't be repeated ... And it already rejected the 3 in the third slot
I only got it because it was the only remaining option with the numbers and operators available, and had it not been I would've tried anything else as I did not think Nerdl did what it did today!That's disgraceful.![]()
