updated my UDMP today and it now won't finish booting.
I can't access the control panel /portal and also can't download config backups via SCP as it refuses connections.
Really don't want to do a reset and go through all the setup again![]()
From reading on the UBNT forums you are not alone and it looks like a full reset and recovery from backup is your best bet. The controller should have been making automatic backups so assuming you took any copies at all, you should be able to restore your system easily enough.
