you can RMA it.Do I contact seasonic and try for rma or is it pointless?
actually seasonic will accept the RMA, because it is classed as a fault (and has done since the vega64 days)You can't RMA if it's because the hardware needs more power the PSU cutting out is actually protection
You can't RMA if it's because the hardware needs more power the PSU cutting out is actually protection you could still RMA for them to test I guess
You can either drastically undervolt the gpu so it uses much lower power that will confirm it
YouTube / Google Search 3080 undervolting afterburner
Or buy higher capacity PSU I would go 1000w+ if want to future proof might be better to do higher considering whats being talked about power usage on next gen
and i've also previously RMAed my focus+ due to the same issues that OP is facing
My concern is that I've had this psu for four years, might not have all the cables/box etc. I'll give them a message. Anything you recommend I mention to speed the process up? Any key phrases you used etc? Thanks.actually seasonic will accept the RMA, because it is classed as a fault (and has done since the vega64 days)
Appreciate the answer. It's not as simple as that. IMO 750,gold 80 rated is ample for this system. Yes, I have an 8700K overclocked and a relative power hungry 3080 that takes 320w under load but you (figuratively, not aimed at uscool) can't tell me that the rest of my system requires the remaining 430W? I'm generalising here, I know I can't count each w out like that but you get my point, that the issue is not 'lack of watts'. Seasonic themselves are saying their protection is sensitive and something is almost a false positive for lack of a better word.
I will contact them and try my luck, though I suspect I'm in for weeks of "it's clearly the new GPU at fault" from them.
Well in the interest of transparency... I'm an using two separate cables on the 3080, BUT I was using a single connector daisy chained for 4 years on the 980ti. Total oversight on my part because 'it worked' and I honestly didn't know it wasn't recommended.Yeah I corrected myself they can test it and confirm if it's ok or not
Just doing the undervolting could answer the spiking is probably causing it 750w isn't that much
Also hasn't said if he has saperate PCIe cables connecting to the gpu or daisy ?
First task of today. Soon as I've had this bacon butty I'm cracking on...Why not undervolt so gpu uses like 250w and test again ?
Yup. I saw that on a Jayz2C video recently and instant self reflecting facepalmYeah it's recommended to use each PCIe cable from PSU and not daisy chained
OK so just installed MSI AB and set up a profile. Dropped the Clock:Voltage curve down by ~100mV and The Witcher 3 fires up beautifully. Getting 100FPS constantly but getting the odd stutter as the FPS drops occasionally, presumably due to hairworks etc. Going to restart and put my OC back in and continue testing.
Quick question about this undervolting though... it seems quite popular, and a lot of people showing evidence of reducing power consumption by 33% at times with little to no performance drop. Why is the stock power consumption so aggressive if it can run stable and safe with such a massive drop in power?
This is my line of thinking too, however I'm not treating undervolting as my fix, but instead more of a proof that the PSU is acting up. I've made a custom curve in MSI AB which keeps my boost clock at 1850 but doesn't let lowers the voltage to about 950mV. Stable so far, and that's with my CPU clock bumped back up to 4.8Ghz.so if its working now the power was too much for the PSU ?
personally wouldnt wanna drop back to 60 just feels stuttery now especially when panning around after getting used to 100fps+ even notice the difference in normal windows use , I would also use MSI AIB overlay so you can see how much CPU is getting used when it stutters and keep eye on GPU clocks and temps power usage etc
I see that you have Acer Predator X34A 1440p 100 Hz
I would search the model of 3080 you have for undervolting so you have an idea what to play around, Personally myself I wanted to match stock performance with undervolting but ended up actually beating stock peformance while lowering power use and lower temps
